OS 50 SX Ringed
OS 50 SX Ringed
Need help wiith new OS 50 SX Ringed. I have been trying to break in this engine new from box. Seemed to run only on primed fuel for a few seconds and conked off. 2 turns on needle valve, full throttle and OS #8 plug. No adjustment done to slow idle screw from box. Fuel : 22% oil ( 50% Syn, 50% castor ) and 5% nitro. Running from bench with properly set up tank and plumbling. No blockade anywhere.
Cheers
Cheers
RE: OS 50 SX Ringed
If the engine's not drawing fuel, and the fuel system has no blockage, then you need to look at the needle and carb.
Open the throttle to full and look into the carburetor. You should see about a 3 mm gap between the needle and the nozzle. Many times, the idle needle's been set too lean, and that can block fuel flow.
RE: OS 50 SX Ringed
ORIGINAL: Bax
RE: OS 50 SX Ringed
Thanks, Bax. Got the engine running on song now. I opened the slow idle needle to 3mm as recommended and 3 turns on the needle valve. Will fine tune it now.
