OS 120 S w/pump
OS 120 S w/pump
I picked up a 120 today and do not have the manual for the engine. On the back of the pump the previous owner put a small lenght of fuel line over two of the fuel input/output. I need to know which one is the intake for fuel and does the second one go back to the tank or just plug off??
RE: OS 120 S w/pump
Thanks for your assisatnce, by the E-Manuals it appears that I have the Surpass II and prior to getting the manual I did a little deductive reasoning and had the plumbing worked out. The engine will start perfectly and idles super, top end is great and I got to maiden my plane this weekend and must say this engine is great. Only thing I need to know now is about setting the low end, in the manuals there is no reference to setting lowend and if you come back to a low speed for extended time in flight it seems to load up slightly, not enough to worry about but would like to know if it can be tweaked out.
