O.S 18 TM
O.S 18 TM
I am thinking about getting a O.S 18 tm to fit in my t-maxx. On the tower hobbies website is says that you have to fit the crankshaft from the 18TZ-S to use the EZ start with the 18 tm. I dont understand why you can use the pull start but you need to get a new crankshaft for the EZ start. As both the pull start and the EZ start use the same one way bearings.
Also what would i need to do to my t-maxx to put the O.S 18 TZ in it? Because i that engine looks like it has about twice the power of the 18tm.
RE: O.S 18 TM
I fitted my os 18 tm 2 days ago and everything is direct fit ,
The engine just fits in on the engine mount & the ez-start just slides right on and screws on perfect !
Just a few adjustments to the throttle and done !
