OS 160FX Stock or Pitts Muffler
Hello, Thanks in advance for your response...I will be using an OS 160FX in a 14 lb aerobatic and I can use either muffler...the stock or the Bisson pitts style..any advantage of one over the other.thanks wc
IL
WC, if you can use stock, definitely, undoubtedly, without question, do so. The pitts mufflers create an inexpensive option for a tight fitting application, but at the expense of your motor's performance, proper back pressure and cooling, and, in the long run, longevity of the engine.
