OS 1.20 Surpass W/pump fuel line hookup?
My Feedback: (20)
GA
Hi, I just picked up a older OS 1.20 Surpass w/pump, but did not get a manual with it. I have attached a picture of the pump in hopes that you could show me a diagram on how it hooks up to the fuel tank. I was told that the fuel tank has to have 3 lines out of it. Any help would be appreciated.
Sincerely,
Dan
Sincerely,
Dan
My Feedback: (9)
SD
RE: OS 1.20 Surpass W/pump fuel line hookup?
Sir; I have the same problem on how to hook up the fuel system on my 120 surpass ll with a pump any info would be greatly appreciated. Thanks Gene
Please see the above reply. If you have the FS-120 with the brass screw on the pump, you have the FS-120 Surpass I. If it has no brass screw, but does have the velocity stack on the carb, you have the FS-120 Surpass II. Black rocker cover is on the FS-120 Surpass III, and those instructions are on the O.S. website.
