O.S. Engines Support Ask Bill Baxter your questions about O.S. Engines.
OS 140 RX pipe tuning procedure
Old 10-24-2005, 02:13 PM
stek79
Default OS 140 RX pipe tuning procedure
Hi Bax,
I'm an owner of a 140 RX that will fly next year... now I have a simple question: what is the correct procedure to assess pipe length?
I've read what the manual says, but I've heard of other useful tests to be done in flight that permit a proper setting, for example eliminating mid-range richness and so on.
Do you have some good information? Docs, web pages, ...
Thank you!!!!!!!!!!
Old 10-25-2005, 10:25 AM
Bax
Default RE: OS 140 RX pipe tuning procedure
We really don't have an FAQ or manual for tuning a pipe. Basically, though, tuning will be different for each airplane/engine/prop/fuel combination. Change the prop, retune the pipe.
You need to make sure the engine is well broken-in, first. If not, you'll waste your time working with the pipe.
To tune the pipe, you start out with it too long. Start the engine, run to full throttle, lean to peak RPM and record the RPM. Stop the engine. Shorten the header 1/4". Restart, retune, record. and stop. As long as the peaked RPM increases, you can shorten the pipe. When you get a decrease in RPM, or no increase, stop. Lengthen 1/4" and fly. Listen to the model. You'll definitely hear it when it's on the pipe versus not on the pipe.
A pipe that's a bit short for the RPM will make the engine trend lean. A long pipe will trend rich. Lower RPM means longer pipes, and vice-versa.
Please be aware that pipes are tuned for a rather narrow RPM range, so you need the pipe to be tuned for where you need it. Usually on uplines in Pattern aircraft, and level on racers.
Hope this helps.
Old 10-25-2005, 10:26 AM
Bax
You MUST stop the engine before changing the pipe length. You cannot "trombone" it or the tuning won't work. Also, you have to allow the engine to run long enough to heat up the pipe before you final-tune and take an RPM reading. A cold pipe won't work correctly.
Hope this helps.
