.12 tz break in
.12 tz break in
Just guessing, but does the carb come pre set or do I need to set it? Tried like crazy to get it started and it sucked down a half a tank and didnt even fire, just like dumping gas in and out.
I did get it set and running, very rich the few couple of tanks, and them as booklet said to do.
This little .12tz is just a crazy little power plant, already ate a set of tires. Just saying thanks for helping out on a few questions I had. Thanks
RE: .12 tz break in
You have to set the carburetor on all glow engines. The settings will actually change from day-to-day. Breakin for your engine will involve driving it and accelerating up to full and back down. You gradually work the high-speed needle towards peak RPM, but do not go lean of peak.
we're glad y ou're enjoying the engine.
