OS 70 FS Bearing ?
MN
OS 70 FS Bearing ?
I have a 1.5 year old FS-70II. I tried to go flying today and it would not crank-over. I tried cranking it by hand thinking it was hydrolic (sp?) lock. But it would not turn over. I took it home and dissassembled it. I removed the head, and back crankcase cover. I found spare metal shavings loose in the crankcase. Upon further inspection, I noticed that one of the balls in the rear ball bearing ring was missing. I suspect that a ball was busted. The engine did not undergo extreme stress before today. If I sent this in to be repared, would this be covered by warranty? Has anyone experienced this problem before?
Thank you for your help.
