91 fx with a 61 size pitts muffler
i have a brand new os 91 fx and want to use it on the top flite piper arrow II with a 61 size pitts muffler , the exhuast port ( size ) of both the engines is the same,
do the experts think there will be any problem with the same
RE: 91 fx with a 61 size pitts muffler
Try it and see. If the engine doesn' t overheat, you'll be OK. Many muffler makers use the same size can and pipes and just change the adaptor to fit different engines. The main consideration is making sure your engine gets good air cooling inside the cowl. Make sure that air coming into the cowl actually passes through the engine's fins.
