propeller for os 120 AX
Hello:
Reading the manual of this engine, O.S. suggests propellers from 15x10-12 to 16x8-10
Reading your web, I check you recommend 14x10 and 15x6 APC propellers
Rpm range of this engine is between 1,800 and 9,500
My engine reaches 9,200 rpm using a 16x8 Master Airscrew propeller
Don't you think you will damage the engine with a so small propellers?
Thanks in advance
Thanks in advance
