FS 91 V FS 91 pumped
Can anyone advise what the advantages are of the pumped version of the FS 91 over the standard version. I assume it's just a matter of more consitent running characteristics.
Many thanks.
Many thanks.
Russ,
The pumped version of the O.S. Max FS-91 frees you from any problems that may be associated with the fuel tank location. You can place the fuel tank back in the fuselage over the C.G. of the model and not worry about fuel supply to the engine.
The peak power output of the pumped and non-pumped engines is the same.
