OS. FX 1.60
OS. FX 1.60
I need to know what type fuel I should use in my 1.60. I am currently using Omega 15% with castor and synthetic blend. I'm not sure without looking at the jug as to percentages, but I also use it in my OS 91 surpass. I had a mishap with my 300ex because my 160 died on a turn around resulting from a short landing. I was wondering if I should be using a little cooler fuel. I am turning a 18/8 Zinger prop and it pulls quite well with this. Also having some trouble with low to high throttle transition ,but after reading some of your posts on this problem I think I may be able to work it out. I am using a Brisson Pitts style muffler. Could I be having some fuel pressure issues with this muffler and if so what would you reccomend doing to correct this problem? I have flown the plane once as fall came too quickly and I had to make some repairs on the plane.
Thanks for your help
Chuck L.
Chuck L.
