Piston Replacement on 1.60 FX
MI
Bax,
Can I just install a new piston and ring without replacing the cylinder liner?
My cylinder is in pretty good shape, however my piston is scored(used engine,never again[:@]).
Anyway, my thought was to just use a BB style brake cylinder hone or a homemade flap wheel to just "break the glaze" in the cylinder.
Any thoughts?
Any thoughts?
RE: Piston Replacement on 1.60 FX
If the liner's find, you don't need to replace it. You may need to lightly clean it with 400-600 grit sandpaper to break any glaze on it, or lightly run a brake cylinder hone through it. Once you've reassembled the engine, break it in as if it were brand-new.
