OS 1.60FX, Enough Power?
RE: OS 1.60FX, Enough Power?
What engine sizes are recommended for that model? We're not particularly familiar with it. Weight is not the only criterion as to whether an engine will fly a particlar model. On one particular engine, you can fly a Cub-type of model that's a lot heavier than a small-winged warbird, or even an aerobatic model. Likely, the 1.60-size engine is in the lower-end of the model's power range, so it will likely allow you to fly the model, but you won't necessarily have a fast or particularly aerobatic one.
My Feedback: (13)
I have seen moki 1.80s on 1/5 scale spitfires in the 17-19 lb range fly fine, so I would have to think it should be fine. however, that plane may need more nose weight than the 1.60 offers, making you add more weight to balance
