os .18 carb adjustment help!!!!!!
i just put a .18 in my winner sport3 did the break-in followed instructions how to adjust carb
now today went to start runs for a couple seconds spitting raw fuel out exhaust pipe
what is the setting for the stop,idle and mixture screws or close enough so i can get it running and then adjust. any other advise will be great! thanks
RE: os .18 carb adjustment help!!!!!!
The settings in the instructions are starting points. Usually, they are rich, you'll need to lean them from there. We'd not be able to give you a setting because they will change from day-to-day, as the weather changes. Spitting raw fuel out of the exhaust pipe indicates a very rich mixture.
