Can I convert my .15 CV-X recoil to electric start
WI
I'm wondering if it's possible to put an electric starter on my OS .15 CV-x w/recoil starter. Thanks for the help.
RE: Can I convert my .15 CV-X recoil to electric start
Yes, but you need the kind that can adapt to the start shaft that normally goes into the recoil units. They are all made by 3rd-party makers, so you'll have to check their info to see which ones will specifically work with your engine.
I've done that with all my pull start engines including a 15 CV-X.
I pulled the pull start off the back to expose the starter shaft. I then took the one-way bearing out and wrapped a couple of layers of vinyl tape arround it and stuffed it into socket from a standard socket set (9/16th I think). I stick that on an adapter and then on to a 12v cordless drill. To use, I just press the bearing onto the shaft and pull the trigger. The tape keeps the one-way bearing in the socket when I pull it away. Works great...
Just make sure you are careful to spin it in the right direction and you use a drill that is not too powerful. 12v Black and Decker seems about right.
