.21 WM Flex Shaft Problems
CT
I recently put the XM on my ts2. I love this motor, man you guys at O.S. really know haow to build a great engine.
Today I brought it to our club "race" (not really a race) to start tunning it out. It ran so well until I threw the flex shaft. I don't really understand how this happened since I didn't hit any thing and the motor is so new... All i did was give it gas and it started revving and not moving.. At first we though I spun the prop but after pulling it out we found the end of the flex shaft shredded. A couple guys I run with said I should contact O.S. about this because it happened right after break in. I would like to know if there is anything that you can do about this unusual problem (unusual being that this was just after break in with less than a gallon through it).
Thank you for you time and consideration,
Matt
Matt
