*OS 120AX Sounds Rough*
My Feedback: (10)
I have the 120AX and probably have about 2 gallons of fuel through it and it is beginning to sound rough when it runs, especially when it idles. I've read some post of others having bearing failure early on. Do you know of a problem in this area?
RE: *OS 120AX Sounds Rough*
We haven't seen much with the O.S. Max 1.20 AX engine. If the bearings are failing, the warranty should apply. Pull the rear cover to take a look. If it's corrosion, you may need to check to see why. If they are just falling apart, then by all means, send it to the service center.
