Inverted OS 70 Surpass II run problems
My Feedback: (10)
VA
I have a new OS70 Surpass II in a Sig Sundancer. I've tried many different needle settings but the thing will not run with the engine inverted. When glow heat is removed it dies reguardless of throttle position, Any solutions without repositioning the fuel tank. There isn't any space to to lower the fuel tank. Right now my only other option is to buy a new cowl & mount it on its side. Help! Thanks.
RE: Inverted OS 70 Surpass II run problems
First off, how does the engine run when you have it upright? You need to get the engine 'dialed in' with it upright, first. Then see how it runs inverted. Your symptoms sound like the engine's much too rich. Either remove the engine from the model and get it set up on a test stand, or mount the fuselage inverted in a cradle and get the engine set up there.
Once you have it well set up in the upright position, you should not need much adjustment when you invert it.
If the fuel tank's too high, you may never be able to solve your difficulty. The center of the tank should be a bit lower than the center of the carburetor, but no more than about 3/8" lower.
My Feedback: (10)
VA
I have run the engine in upright. I called Hobby Services & was told to put a Perry pump on it & was told that this will solve the problem. Is this true or did I just waste my time & money. My pump should be here from Tower on friday. When I ordered the Sundancer from Tower I called Hobby Services & was told then that the OS 70 was the best engine combo for this plane. I've had many planes & motors over the past 17 years & have never had this kind of problem. I can't lower the fuel tank any lower because it about as low as I can get it now. I almost ordered a YS.63 for this plane now I wish I had.
We'd not know who would recommend a pump. You'd need a pump if the tank's far away from the engine, or the tank was very, very low.
Inverted running can make engines be problematic to run. You may also try a new glow plug. Many times, if the engine quits when you remove the battery lead, it's a plug problem. Use an O.S. Type F plug.
If the engine runs properly upright or side-mounted, then there's nothing wrong with the engine. You may need to run an on-board ignition system to get good inverted running at lower throttle levels. The engine should be fine at full throttle.
My Feedback: (10)
VA
This really Pi**es me off. Your guys gave me bad advice. Now even if i return it I will have to pay shipping & I ask If I should buy an onboard glow system instead & was told no it wouldn't help. You need to find out who told me to buy a pump. If your guys don't know what they are doing then you need to get someone that does.[>:]
I had a similar problem with a YS110 because of the wrong type of plug. I'm now using F-plus and onbord glow at idle. Problem solved.
Are you using an F plug?
Hi. Please forgive me for not speak so good english.
However. I just have the same problem with my O.S 91 surpass, the engine will die as soon I take the glow-heater away. I have try many different of settings but in the end it looks like it get too rich(mounted the right way it works perfect). Then i changed the fuellines to a line with a little smaller inner dia. and suddenly it works. Now it´s running perfect and m a happy O.S pilot. The engine is mounted in a Midwest Citabria 80"
WI
I have an os 70 mounted inverted with the fuel tank center line about 3/4" to 1"below the centerline of the carb. This seems to be the right combination as I also have two os90's with the tank mounted on a level with the carb centerline and they don't run well at all at idle without glo heat, but do run good at WOT.
My Feedback: (10)
VA
I changed my fuel & it runs great inverted. I've run both 15% & 30% cool power Heli fuel with good results. It seems to idle a little better on the 30% & it makes nice smoke. This motor is strong, strong, strong. Thanks Bax for the help.
