Crankshaft endplay
Crankshaft endplay
I have an OS.65LA. I noticed that there is a bit of play (in and out) when I pull on the crank shaft. Doing so causes and audible clicking sound that is also noticeable when flying the plane it is installed on. The engine otherwise runs fine. Is this something that is normal? Or is this a sign that the bushings are worn or something else gone awry?
