Adding After Run Oil in 4-stroke
PA
How do I put after run oil into my OS FS 70 Surpass ll 4-stroke engine?
Can I just remove the glow plug and add a few drops into the hole then flip the prop a few times?
jimmy
jimmy
CA
RE: Adding After Run Oil in 4-stroke
Turn the engine over and add a tablespoons worth of oil in the crankcase vent-hole. Cylce the engine over manually about four times and you're good to go.
PA
Upon further review I read the manual and it says to take out the glow plug and add a few drops of after run oil into the plug hole then flip the prop over a few times.
Thanks for your reply,
jimmy
jimmy
