OS50 SX-H 5B carb
OS50 SX-H 5B carb
Anyone know if the 5B carb is the stock carb fitted to the OS50. If its not, whats the difference between the 5B and the stock carb?
OS50 SX-H 5B carb
skycom,
The O.S. Max .50 SX-H heli engine comes with a #40E carb. The #5B carb came on the old O.S. Max .50 FSR-H. They are entirely different design carburetors.
The old #5B came with the idle mixture adjustement screw in the center of the throttle arm. The #40E uses an idle mixture valve that's similar to the carbs in the larger engines.
The #5B is very similar in construction to the #60F carb used in the O.S. Max 1.60 FX.
You can check the exploded views of the #40 E and #60F at:
http://www.osengines.com/parts/exploded-views.html
