removing bearings in 46FX?
KY
I'm going to replace the rusty bearings in a 46FX. What is the best way to get the front bearing out? I've read about heating the case but with what...a torch, a heat gun or a hair dryer? I don't want to over heat it. I did it once before a few years ago without heat and it way a bugger!
Thanks, David
Thanks, David
RE: removing bearings in 46FX?
We have completely-disassembled the engine so that only the case and bearings is left. We then use a small propane torch. Just make sure to gently heat the case evenly. We move the flame all around the case to heat it up.
You can also use a heat gun, which takes a bit longer, and even use an oven...heat the engine to about 250-300 degrees F.
When the case has been heated, you just need to rap it against a block of wood and the bearings should just fall right out.
To install new bearings, heat the case (do NOT heat the bearings). You can then slide the rear bearing onto the crank, slide them into the case, slide the front bearing onto the crank and case, and make sure they're fully-seated. We usually use a piece of rod against the back of the crankshaft to tap the bearing into place. Using the crank insures that you install the bearings with the proper alignment.
Let the case cool, remove the crank to eliminate any loading on the bearings, and then reassemble the engine.
WI
If you have the sleeve out, first mark the connecting rod with a Sharpie to identify the back of the rod. You want to put the rod back on with the mark facing you. Take the piston to bottom dead center. With the piston free of the liner there is enough slop to allow you to now be able to pull the rod off of the pin.
My Feedback: (202)
Bax, I figured that out right after I posted question. The engine was gummed-up and the rod was tight on the wristpin. I warmed the engine in the oven at 300 degrees for a very short period and everything loosened up. My wife came home and asked "what stinks?" LOL!!! I recently purchase the engine here on RCU. It was advertised as "bench ran only". Upon receiving it I immediately noticed signs of rust. I removed backplate and the horror struck. I completely dissassembled the engine. cleaned it internally including the carb. I am replacing the bearings. This is an excellent example of what happens when you run an engine and then simply put it back in the box without running out unspent fuel and no after-run oil. The engine is basically new but the bearings,crank, and carb barrel were under attack by the dreaded effects of oxidation/corrosion (RUST). The engine has been saved and the seller made restitution with me. Speedy
WI
ORIGINAL: Speedy-Gonzales
My wife wasn't a big fan of me stinking up the oven either, but this solution seems to work well.
