120AX
RE: 120AX
No. The O.S. Max 1.20 AX has about the same overall volume as the .91 FX...that is, it takes up about the same amount of space in the airplane. The bolt pattern is very different.
The .91 has a crankcase that's 42.6 mm wide, the 1.20 is 46.5 mm.
The O.S. website states that they are "virtually identical" in size: http://www.osengines.com/engines/osmg0650.html
