O.S. Engines Support Ask Bill Baxter your questions about O.S. Engines.
OS FS 200 & 200FI
Old 12-27-2006, 09:13 PM
elmer
Default OS FS 200 & 200FI
Bax
Dont know if you have any info yet but I see tower hobbies have the OS FS 200 as being available sometime
in april. Do you have any additional info on when the 200 FS fuel injected version might be available.
Just fishing, dont want to go YS
Elmer Fud
Old 12-28-2006, 10:39 AM
Bax
Default RE: OS FS 200 & 200FI
The best information we have right now on the O.S. FS-200 is that it will be available in late Spring of 2007. We have no information on other versions of the engine.
Old 08-30-2012, 12:26 PM
speed-panzer
speed-panzer's Avatar
Hi,
on my new FS200-P I messed up the correct setting of camshaft gear to crankshaft screw gear. My intention was to give a few drops of oil to the camshaft before initial break-in run. During pulling the camshaft case lid with its tiny bearing, the camshaft little pit popped up and lost its setting on the crank gear.
The small mark on the camshaft gear is clearly visible.
How to set it back in correct order?
thanks
Dominik
