Tuned exaust
OH
Tuned exaust
Ive got a .61fx and am looking to get more power with tuned exaust. What would be best for this a tuned muffler like the one from Jett or a tuned pipe like a Macs pipe. Also heard that Performance Specialties Ultra Thrust is a good one.Where could I find it? Thanks for any info
RE: Tuned exaust
The power "increase" with a tuned exhaust system is entirely dependent upon the RPM level you wish to run the engine. An engine tuned for RPM will use a different propeller and pipe setup than one for torque. Please realize that a tuned exhaust system will only be good for a very narrow RPM band, and most people with pipes tune for maximum RPM. Once you retard the throttle below maximum, the pipe becomes a very large muffler that gives you no boost.
Almost anybody's .61-sized tuned pipe will work for you. That's because you'll have to tune the exhaust system to match your engine/prop/fuel combination. Change any of those things, and you'll have to retune the exhaust system.
OH
RE: Tuned exaust
Thankyou,
What about the pretuned mufflers like the one from jett, do they give as much power as the tuned pipes. Also do you know where I could find the Performance Specalties Ultra Thrust Mufflers?
