1.60 FX in a Spitfire
NM
Hi Bax, I'll be using a 1.60 in about a 15lb Spitfire. I want to use a 10" pitch, as it will look best going fast. No need for vertical, or 3D here. What diameter with the 10" pitch would you suggest ? I guess I'm asking, what RPM the 1.60 is going to be happiest at for reliable performance ? What should I Tach it at ?
> Jim
> Jim
RE: 1.60 FX in a Spitfire
We'd expect an APC 16 x 10 propeller to turn RPM in the mid 8,000's with the stock exhaust system. If you went to a slightly-smaller diameter, and the resultant higher RPM, you'll get a bit more airspeed. Please remember that a propeller for speed doesn't climb as well and takes more distance for takeoff. It also has less of a braking effect when you idle down for landing.
NM
ORIGINAL: Bax
Thanks Bax.
> Jim
