OS 46 AX won't turn over freely
NY
Just picked up a 46AX today, tried to turn engine over with glow plug removed but it sticks at the top of the stroke. Is this normal, will this go away after break in, or should I return it?
Thanks for any info.
Raven
Raven
WA
RE: OS 46 AX won't turn over freely
[size=3][color=#990099][/b]
That is normal...
There is no piston ring so the cilinder liner has a taper to it...
You should not "WARM UP" at low rpms with this type of motor..
Ringed motors you can warm up....
That is normal...
This FAQ should answer your questions. It also applies to the new O.S. Max ABL engines:
http://www.osengines.com/faq/product-faq.html#q1
