OS 18TZ Head Temperature
TX
1. What is the head temp where the danger zone starts for sustained high-end lap racing (3-4 minutes)?
2. Is there a sweet spot temp range (30% nitro)?
3. What is the RPM range for maximum power? maximum torque?
RE: OS 18TZ Head Temperature
It's not possible for us to give you an actual temperature or temperature range for your engine. The specific temperature is determined by too many factors. There is only one way to determine at what temperature your engine should be run. You have to run it first and then find out what temperature the engine reaches.
Make sure your engine is operating properly with the performance you expect. Use the exact setup every time...fuel, exhaust system, plug, measurement location, and so forth. If you change anything, the temperature will change. Once you have the engine running the way you want it. Take your measurement. This is your starting point. You will have to take measurements over time to find out how the weather affects it. As the air temperature and humidity change from day-to-day, the operating temperature will change. Eventually, you'll find a temperature range that you can work with.
Engine temperature is not an absolute number for setting your engine. It is only a guide, and can help alert you to potential problems. The only sure way to make sure your engine is running correctly is to see how it's running. An engine can be operating at "correct" temperatures, but not running well.
Finally, use any temperatures you read about, or people tell you, as rough information. The only useful numbers are the ones you actually measure when your engine is running correctly. If your engine is running correctly, then what you measure is correct, even if some else says it's too high or too low. Don't worry about the differences. Each engine is in a unique installation with a unique set of circumstances, so there can be wide variances in engine temperature.
