FT-300 Slow Transition
Hello,
I have a FT300 installed in a GP CEII. The engine is not new, but it seemed to be perfectly fine until lately. My problem is the stransition from idle to full throtle. It takes around 2 secs to respond. If I leave it running in idle for around 30 sec. the transition is much worse. When landing this gets critical if wanting to add 1 or 2 clicks of throtle.
After landing and runing the engine on idle (after a 10 min flight), I get an oscilating sound (variation of RPM's).
I've noticed one piston with a slightly better compresion than the other one. Also, when tuning, I see one cilinder seems to run leaner than the other one. Reading through the forums I understand this is normal.
I would appreciate it if you could give me ideas or directions of how to fix my engine. It seems that the 2 variables are the valve clearance and the "mixture control screw". I've tried moving the screw an 1/8" of a turn at a time both ways with no good results.
Any help would be appreciated.
Thanks.
Thanks.
RE: FT-300 Slow Transition
Thanks for the info Bax.. I do run my engine with a McDaniels on board glow driver system. That works great. Just to make sure I'm doing the idle mixture correct, turning the screw clockwise = leaner, turning the screw counter-clockwise = richer, correct? Just want to make sure because the screw moves out when turning clockwise.
thanks again!
thanks again!
