744 muffler alternatives
TX
I lost the tail cone on my os 50 max (currently replaced with a Old Spice Deodorant spray can). The muffler is a 744. Can you suggest a replacement muffler for the 744? The mounting holes are 34mm on center and the port is 8mm x 20mm. I also have a 61fsr that uses this muffler so I may have problems with it someday. Thanks in advance for your advice.
RE: 744 muffler alternatives
The O.S. Max #744 muffler is long discontinued. None of the current mufflers have similar mounting dimensions, so we'd not have one that would fit. You could, of course, take any of the .61-size mufflers and make your own adaptor for them. That would work.
