O.S. 1.20 AX Remote Needle Valve ??
My Feedback: (15)
CA
I would like to use a remote needle valve with my O.S. 1.20 AX and was considering using the O.S. remote needle valve assembly #9B would this work correctly or is there a better choice. Also, after the remote valve is installed should I just open the needle valve on the carburetor to full rich or remove it and plug the hole with a cap of some kind??
Thank you!
Thank you!
RE: O.S. 1.20 AX Remote Needle Valve ??
The #9B remote needle valve assembly will work fine with the 1.20 AX. This assembly comes with a plug that replaces the stock needle valve on the engine.
David Wolf, Senior Product Support Supervisor
3002 N. Apollo Dr. Ste. 1 Champaign, IL 61822 USA
Phone: 217 398-8970
Email: [email protected]
Phone: 217 398-8970
