Breaking in OS 1.20 AX for pusher config
QC, CANADA
I purchased an OS 1.20 AX for a Velocity XL. This airplane uses a pusher prop. Is there a correct way to break in the engine for this configuration? Can I break in the engine on a test stand using a tractor prop and then use it with a pusher prop?
Thanks for the advice.
