OS-40LA idle problem
I've got an OS-40LA mounted on its side in a GP J3 Piper Cub, using a pitts style muffler and pressured tank and cool power 15% nitro fuel. When it was new (4 yrs old now) it ran just fine but now I'm having a bear of a time keeping it running at less than 1/2 throttle, especially on approaches and landing. I'm pretty sure it's an idle-screw (bleed) problem - it's probably WAY off.
Where should I re-set it to get something of an idle again? Getting rather tired of dead-stick landings (have to walk too much to retrieve the plane).
Thanks.
Dave W.
Thanks.
Dave W.
RE: OS-40LA idle problem
Yeah, compression's good.
The O.S. Max .40 LA engine should be properly-tuned at full throttle before you start to work on the idle. The air-bleed screw should be initially positioned so that it blocks the air-bleed hole 1.2-way. Turn it in to richen the low-end mixture, and turn it out to lean. If that won't work, then it's possible that the compression fit has become a bit low. The idle is the first thing to go when the piston/cylinder fit starts to wear out.
Hey, yeah - it's quite a bit better now, once again. High-end was just fine but I think I had too much air on the low-end, it's set at about 1 1/3 turn (was nearly 2 turns) from closed now and the engine idles rather nicely again. Thanks a LOT.
Dave W.
Dave W.
