FSa-56 Inverted mounting
How will the FSa-56 react to inverted mounting. I plan on putting it in my 50 Size F3a plane, if i set the needles up correctly on the bench, will it need major changes when inverted? Will the engine run hotter? I dont have much experience with 4c.
RE: FSa-56 Inverted mounting
Well i plan on taking it straight to the plane after benchrun, should i give it double the runin time on the bench?
