fs-91/p breakin problem
Hi, my engine is new and i have a problem whit a break-in, vibration+++ idle and not run on idle, a lot a fuel exit by the carburator. my needle valve is oppening 1 - 1 1/2 turn. The setting is writting in the manual is 2 turns( not run whit my engine)
RE: fs-91/p breakin problem
You break in the engine by using the manual's instructions. The manual's needle settings are only starting points. You will have to adjust and lean the engine from there. After 45 minutes of running or so, you will be able to get the engine leaned to the proper mixture.
