rpm surging 4stroke 52 surrpass
Surging almost through out the rpm range .If tank issues are ruled out so is plumbing what should I check next to rectify the problem? I have also noticed that the HS needle has no effect on rpm for more than one complete turn but would immediately lean the engine if turned a further one or two ticks .Cheers
RE: rpm surging 4stroke 52 surrpass
Please check the entire fuel system. Better yet, remove the engine from the model and put it onto a test stand. Surging is caused by erratic fuel flow. In a model, this can be caused by vibration agitating air into the fuel that's in the tank, or by causing the fuel lines to move about. A leak in a fuel line will be aggravated by the line moving about due to vibration. Using a test stand will fix everything firmly in place, and will allow you to set up the engine properly.
I had the same problem with a Magnum 91 4 stroke. After checking the hoses and fuel tank I found nothing wrong. However I pulled the High speed needle out and disconnected the hose's a blew out the carburetor with air and ran some fuel through it. That solved my surging. Hope this helps.
