18tz(P) crank into a 18tm
Hi, I was wondering if i could use a 18tz (p) sg shaft into my 18tm? I have a 18tz backplate on it already but i want to use a centax clutch setup and the stock crank don't allow me 2. I know the motor was made for offroad but im using it on my onroad and i want to use a different clutch setup.
RE: 18tz(P) crank into a 18tm
We've not tried it, so we can't say if it would work. The porting would be different, at least, so you'd see performance change, likely for the worse. They fit into the same size rear bearing, but again, we don't know about the other dimensions.
You may want to ask in the appropriate car forum to see if anyone's done that. Usually, though, such interchanging doesn't work.
