O.S. Engines Support Ask Bill Baxter your questions about O.S. Engines.
os 18 cv-r break in
Old 02-25-2009, 07:57 AM
fasty
Default os 18 cv-r break in
can some 1 tell me the best way to break in my 18. I read the manual but it doesnt say what temps it shoud be hitting @ break in.or should I not worry about the temps on break in?
I really dont want to hurt this new motor.
never mind I found it on G search http://www.rcuniverse.com/forum/m_2280714/tm.htm
thanks any ways.
Is it me or does this forums search not work that well?
Old 02-25-2009, 11:07 AM
Bax
Default RE: os 18 cv-r break in
You break in the engine by driving the car. Accelerate up and down the parking lot or around the track. You want to run the engine rich, so you may need to keep the battery plugged onto the glow plug for the first few runs, until you get the engine leaned enough so that it will have an idle. DON'T just idle for a tank or two, on or off the ground. That's a sure way to guarantee a shorter engine life. The engine MUST get up to operating temps. You want the engine to be able to get to full throttle at a rich setting.
As you drive the car, lean the high-speed needle a bit at a time until the engine is getting near peak RPM at full throttle. If the engine can sustain high-speed running without the RPM sagging, you're on the rich side of peak RPM. You always want to be on the rich side of peak RPM. Once you get to this point, you can check the temp, if you wish, for a reference. Don't tune to a temp or you'll wind up ruining your engine rather quickly. The temp will change from day-to-day, as the weather changes and you adjust the needle.
The biggest factor for long engine life is lubrication. More oil in the fuel is better. Many so-called "R/C Car" fuels have very little oil. If you're not racing, use an "airplane" fuel. The engine will be a bit rougher on acceleration, but will run much better over time because of the higher oil content. If you race, then you're not really worried about engine life as long as the engine lasts a racing weekend.
Old 02-25-2009, 07:06 PM
fasty
thanks for your help
