OS .81 FS a valve clearance
RE: OS .81 FS a valve clearance
ORIGINAL: DSTIEBS
They should be in the Manual.
-Robert
If you have the valve tool kit, the thin feeler fits and the thick one doesn't when you adjust the valves when they are off the cam. If you have our own gauges, the thin one is 0.04mm and the thick one is 0.10 mm. Again, you have the valves off the cam, and the thin feeler fits and the thick one doesn't.
The tool kit comes with the instructions, too.
OSMG6334 72200060 GAUGES TOOLS 4-STROKE US$11.99
These parts can be ordered through any hobby retailer who sells O.S. Max engines and accessories.
