40 Fx Needle Valve
40 Fx Needle Valve
I recently broke off one of the plastic fuel nipples on the needle valve of my 40 Fx. The break is at the joint of the piece to the main needle valve body. Is there any way to fix it or is there a place that has replacement valves for the engine?
RE: 40 Fx Needle Valve
The O.S. Max .40 FX engine doesn't have plastic fuel nipples. The need valve assembly is part of the rear cover, which is metal, and has metal fittings.
If the nipple on the main housing is broken, you'll need a new rear cover:
OSMG4128 25607100 COVER PLATE 40-46FX US$11.99
The fuel outlet nipple screws into the cover plate.
These parts can be ordered through any hobby retailer who sells O.S. Max engines and accessories.
