120AX bearing change out
IN
Thanks Bill, that helped iin removing the con rod and I was able to remove the front bearing but the rear bearing appears to be pressed in and I'm not sure the best way to remove it...... need your help again..........thanks
RE: 120AX bearing change out
To remove the bearings, you must heat the crankcase. Just clean it thoroughly and place it on a metal tray in a 250-degree F oven until it heat soaks. The bearings should "fall" out. Heat the case again to insert the new bearing...the new bearing is not heated.
