OS 4 Stroke valve kit
Hello,
I recently purchased the valve adjusting kit, but I've found, to my surprise that the wrench does not fit the OS FS-200 (non pumped).
It fits my 91 Surpass just fine but the 200 valve rocker nuts seem to be a little larger. It could also be that the adjusting nut itself is damaged, as I bought the engine second hand but I doubt it as I think I would have noticed that.
I was just wondering if you knew what the correct wrench size for the 200 is (I'm happy to just buy a second wrench).
I assume the valve clearances should be the same as any other OS 4S?
If the wrench *should* fit then I'll pull the rocker cover off again and have another look.
