120 Surpass won't Start after rebuild
I recently replaced the bearings in my 120 Surpass II along with the piston ring and all gaskets. I aligned the cam gear as per the information provided on this forum but it won't start. Is there a difference between TDC on the power stroke and exhaust stroke when it comes to alignment or does it matter? Also I only disconnected the connecting rod from the crank, not the piston. When I reinstalled it, I couldn't remember if it only fit one way or if you can spin it around 180 degrees and connect it that way too. Would either of these be the cause of why the engine won't start or does it not make any difference and my problem lies somewhere else?
Thanks. Steve |
RE: 120 Surpass won't Start after rebuild
Problem solved. The cam must have shifted while I was attaching the cover. When I opened it up, it was 1/4 turn off from where I had lined it up. Set it correctly again and this time noticed it moving while I was attaching the cover so set it again and very carefully screwed the cover in place. Attached the glow driver and hit it with the starter - fired up almost instantly.
We're glad to hear you found out what it was, and that it was simple.
