OS 10 FP questions.
Hello,
I took a few years off from RC to finish my full size Just aircraft. Needless to say, things had changed while I was away. I had been planning to build an F-82 from the .20 size House of Balsa P-51 kits. I was able to scavenge one and a half kits from Ebay, and four OS .10 FP's. I am starting out with building a Sig Wonder Twin with two of the .10's to break them in for the F-82, and install & fly the second pair of engines. All four of the .10's look new, but I discovered this anomaly with the piston in one of them. It has a machined hole in the piston, and I can see the pin & the end of the connecting rod.I am assuming the piston is installed reversed. How difficult is it to correct this? Also, I want to convert the needle valve position to the back plate, so is the fuel nipple & mounting bracket available to do this? Sorry about the bad photo. The phone wouldn't focus well in that area. Thanks! https://cimg3.ibsrv.net/gimg/www.rcu...595f664598.jpg |
I was able to push the sleeve out without
having to preheat. 5 minutes and it was done. |
