Post pics of your other "toys" and interests
Banned
GA
RE: Post pics of your other "toys" and interests
ORIGINAL: Malidrag
Thanks for the info.. Definitly going to stick with what I got in her and just dial her in.. She feels good on the street and I know with what is in her I can get the #'s I want amd still drive her to the local shows..
Its a 1980 Malibu
Its a 1980 Malibu
suspension is 50% (if not more) in getting a car to run the numbers. Its easy to make a car work with a turd motor that has a dead hooking suspension, vs trying to make a **** suspension hook with a bunch of power. You'd be suprised what you can pick up by simplying putting the car on a set of scales and scaling it, setting the preload, etc. Every little bit in getting weight moved around helps... if ya can move the motor back anymore, id get it back as close to the firewall as possible and still be able to adjust the distributor (one thing i HATE about gm motors is the distributor in the back)
I would really go up to a 28" tire (275/60/15 M/T Drag radial would be perfect) with a little more gear, and a looser converter. Id also go with a 8" or so crank pulley not really to make any MORE boost, but make more sooner.
Btw... whos carb are you running? I take it its already got the floats changed and what not to accomidate the boost.
also make sure the back passenger side is loaded more then the drivers side. chevy has a habit of squating to the back passenger side. preloading the back pass side will make the car leave dead flat. it will leave flat and straight if set right.
and run a street slick. et streets are a great tire for the road on dry days and when hot are liek gumballs. cant compare street slicks to drag radials. ive seen soem nice times with et streets and hoosier quicktimes
Banned
GA
ORIGINAL: 45deepvee
pretty much all cars need the peload in the right rear. Thats why you see alot of cars with just the front left tire up in the air and the right rear corner of the bumper trying to drag the ground. The best way to solve that is using an anti-roll bar and getting it adjusted right. For a long time everyone just used an airbag inside the spring (i have one in my 88 convertable mustang). But in order to set the preload and get everything right, the car really needs to be on a set of scales and start moving around whatever weight ya can.
And you might want to read up on the Mickey Thompson drag radials (ET Street Radial they call it). It is 3 (or 4) compounds SOFTER then the ET Drag slicks, with a harder sidewall (basically, a 325/50/15 is a 28x10.5S with a little more patch on the ground, and a softer compound...and DOT legal ). Trust me, the drag radials are the ticket...they are just a bit tricky. I have logs and logs and logs from that orange car when we started running drag radial.. tire pressure, track temp and tire temp play a big role in getting them to work (slicks are the same, just a little more forgiving). We had the best 60' out of anyone in the country on the drag radials with a 1.25, and the best it cut on regular 28x10.5 slicks was 1.26.....and replaced many oil pans and headers from it standing on the bumper, id say the radials work quite well.
Not to mention the drag radial record right now is a 7.40 @ 197 on 295/60/15 M/T drag radials! [X(]
hmm i thought the drag radials were a harder compound. i havent look into street tires much lately since everything my friends have been runnign are on slicks. plu si have sold all my cars because racing got to expensive for me at this point in my life. maybe later on down the road id liek to build a malibu wagon. those thigs are awesome.
right now im workin on puttin a lift kit in y truck. someone put lowerig suspension in it and i got the truck cheap. its got the good ol 4.3L chevy in it. its a 91 s-10 long bed. probably gonna lift it about 2-4 inches and stick 31 or 33 inch swampers under it. run dana 44's front and back with 4:56's and be done with it. things only 2 wheel drive so i have to convert the front to solid axle and im not lookign forward to it. i dont wanna leave it 2wd because then ill just want to swap it later on down the road anyways.
i miss my 79 camaro bad. sold it to a friend and he put it together with a 377. thing came out nice and it just gets to me everytime i go for a ride in it. makes me sad i had to sell it
#31
TN
ORIGINAL: Believe It
nice jr drag.... is that one of the blockzilla's or whatever they call it?
btw is that a elclectus in the background in the picture of your rc drag car? I got a couple big birds as well (umbrella cockatoo, yellow nape amazon, eclectus, ring neck parakeet)
#32
Banned
GA
ORIGINAL: 2916jr
actually it is a rhino one of the biggest jr motors "legal" for jr drag racing and it is a eclectus lol I am the only one she likes she bites everyone else lol
#33
Banned
GA
ORIGINAL: 45deepvee
the BFG's and Nitto's are a harder compound tire. This is the reason organizations like the NMRA outlaw'd the M/T radials in the Drag Radial class... they work that good.
#34
TN
i hear that. My eclectus doesnt like anyone...just sits in her cage pullin all her feathers out. Amazon is the same, she dont like anyone but she says all kinds of stuff..pretty funny bird. Cockatoo only likes 2 men, me and my grandfather. She will not let any other man touch her. I want to get an African Grey, but heard they become 1 person birds, dont need another one of those! LOL
ORIGINAL: 2916jr
#35
OH
We use to get our hands on sprint cars tires,there soft compound tires and they were free bees.I would always to to sit with the front line lock on and light up the tires on my mopar!! Boy I would smoke the tires real good!And man they would hook up good!Oh there the other trick I'd learnd is but the battey in the trunk,but put it on the right side for weight perpouses for the right tire hook up.
#39
Don't feel bad Ryan, you're not the only one.
Oh yeah, BOOOOOO, HISSSSS on the Fender! I work about 2 blocks north of the original Gibson factory where Heritage guitars are now made in part of the building. I can't gripe about the Yamaha drum set though as I have a Yamaha keyboard that I mess around with.
This is sickening. It belongs to one of my brothers. He for tired of waiting for his new Shelby Mustang to show up so he bought this. Maybe he'll let me take it for a drive when he gets it out of hibernation.
#40
ON, CANADA
That looks pretty cool Ron. Hopefully he does let you take it for a spin. I've never really liked Gibson guitars for a few reasons but they do have their time and place.
The yamaha kit is pretty good. They make fairly decent equipment for also making a ton of other stuff including recreational vehicles.
Ryan
Ryan
#44
I will have my camera along the next time that he shows up or when I go out to his house. I'm thinking that he has it in winter storage right now along with his `Vette. He's has a lot of toys the past few years and he let's me drive them but I don't know if he'll trust me behind the wheel of the Viper. Can't blame him actually as he knows that I'll drive the wheels off it!
Mike, don't let Sheila see your posting calling her a toy![X(] Still got that small-block S-10?
#45
Well, I dont have many toys, but my brother's got a pretty cool "toy." Don't know if anyone's into Le mans. He doesn't race the cars but he hauls them around in this truck he had custom built and is on the crew team.
#48
nice lookin motor, I almost bought an SS a while back, but the price was not right.
I really want a grand nat, but then I'm into import cars as well, unfortunately I dont have a picture of my old car. It's not really in the same class as your cars, but I sure loved her. I had a 91 accord ex, with just about everything possible done to it and I did all the work myself, except replacing the entire rear section of the car because of rust. She was all white, slammed to the ground with 17" Enkie Katana rims, full exhaaust(not a whinny one, nice deep tone), cold air intake, ignition, advanced timing, shaved tail lights, custom front end. She was clean, not like most of the imports with big stupid wings on them. Ran a 15.4 at the track, not great, but I dont think it was bad for a naturally aspirated four banger. Really wish I had a picture, amazing you can have a car that you love for so many years and foget to just take one lousy pic. [:@] I now drive a camry, and no I'm not happy about it at all.
#49
Banned
GA
ORIGINAL: misshydro
heh... i use to use Dirt track racing tires all the time. McCreary (which is now American Racer) G60-15's are a hell of a soft tire that get real sticky with just a little bit of heat in em [8D]
