HELP ME OUT TO CHECK THE TECHNICAL FEASIBILITY OF OA PROBLEM
planning to utilise the water power from an overhead tank of 10 meter head
by installing a small turbine with the pipe line.also outlet water should be of
used in taps as water supply.please suggest the feasibility of it using a cross fow
turbine.please note we want 2 use the small power it generate to light up LED
lights.any other mechanism to realise the goal is also invited.
