If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 7 of 7
  1. #1
    Join Date
    Oct 2007
    brisbane, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Fibre glassing
    I know this has nothing to do with the hobby (eccept maybe taking my cold stuff down to the water for the day) but there are some guys in here that i think would have an idea
    I was looking at making my own esky kinda the same as eva cool fibreglass esky for the price you would pay for something so simple is out of control! I think that they would be foam sandwich fibreglass? does poliester resin melt the foam? I was just going to glue up a foam box cove the corners and lay some glass if any one has any input that would be great. are we allowed to do a off topic build like this ?
  2. #2
    Dreamin Hemi's Avatar
    Join Date
    Nov 2004
    Milton, DE
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Fibre glassing
    Poly resins usually will melt foam.
    As far as your build of this project here, post away!. We all love a good build thread. There are several guys including myself that work with glass that will lend you a hand, some do it for a living, others just started. Just ask lots of questions and have fun doing it. Oh yeah...post LOTS of pictures!
    -Scott
    These opinions expressed here are my own and may not necessarily represent the views of RCUniverse.com
  3. #3
    Join Date
    Oct 2007
    brisbane, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Fibre glassing
    Thanks scott well now that slows me down before I even start[] what insulating type material could be used to glass over to make for a good esky?
    or could I maybe put some sort of protective layer over foam prior to glassing
    cheers craig
  4. #4
    Join Date
    Nov 2005
    Riva, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Fibre glassing
    I've never been succesful putting a protective layer over foam and then glassing it. I've tried candlewax, thinned elmers glue, and polycrylic. None of it survived the polyester resin. A much more simpler method, although somewhat more pricey, would be to use an epoxy like the west sytems stuff. You can get it at boat stores. it cures good and hard, won't melt the foam, and is pretty tough, much more resistant to cracking than polyester.
    Just my 2c
    Kurt
  5. #5
    Join Date
    Nov 2004
    Milton, DE
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Fibre glassing
    ORIGINAL: munro1656
    cheers craig
    When I use foam, it's usually in plug making. I typically have a layer of Bondo or other type body filler over the foam that makes my barrier. I have seen people using packaging tape and wraping the part to be glassed. Have also personally used latex paint over the foam for my little parts like wheen pants and cowls for my planes. Maybe try to experiment with a small foam part and see what happens?!?!
  6. #6
    Join Date
    Oct 2007
    brisbane, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Fibre glassing
    well after heaps of searching and phone calls I found some foam that polyester resin will not melt so I got a sheet 2400 by 1200 so i'll have enough to make two esky's and sell one I have cut out my pieces and glue together and gave all a rub over to blend in joins in and round off corners. Next I cut some 12mm ply and inserted it were hinges and handles will be for a bit of strength I'll be using 450g chop for the lay how many layers would I need??
    cheers craig
  7. #7
    Join Date
    Oct 2007
    brisbane, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Fibre glassing
    I'm having big troubles uploading these photos[:@] they will begin to upload then stop for no reason
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
