Who can get the most distance.
RE: Who can get the most distance.
Um, difficult to say, I start way in the top left, drag really fast (I have a 2000 dpi laser mouse set to max sensitivity), and i drag to the line approx in the vertical centre, then let go before it forces me too. It should peak just after the fan and fly out through the top half of the window. Interestingly, the record run did NOT make a loop the loop. Go figure.
WI
ok heres the trick
put your plain all the way up in the corner and move the mouse cursor out of the game box and go around it and then go back in the area were its marked in red and that should get you out the window + get distance
