THE LOUNGE 3...
#2629
CA
RE: THE LOUNGE 3...
Happy B-day Moron . Well "just for you" I got my RC10 going... thanks for the eeer prodding to get it moving. Actually is a fun car [X(]. Time to fix up the tranny and go smite those peewee racers [8D]
#2636
RE: THE LOUNGE 3...
ORIGINAL: turbotb0205
on another note.. any of you uber tamiya guys ''lee LB secret'' have a gear set for a stadium blitzer lying around? lol.. i found one on ebay but the dude wants 20$ plus 12 shipping
and shipping would be pricey (10 Euro's) though its the same no matter how many parts you order..
ORIGINAL: Eman77
Lee, by ''reset'', do you mean you re-calibrated your MM ESC with the different Tx? If so, I would think that would do the trick.
Also, when you moved the MM ESC to a different vehicle to test, were the batteries/motor different? If so, maybe there's a CastleLink setting specific to your other vehicle setup (LiPo cutoff but you're running NiMh, something else) that's goofing you up.
Hope you figure it out!
also i did try setting the start power to high on the Cayenne, which made no difference..
ORIGINAL: Lunchboxer
Lee, running on 3 cylnders?! You better get that checked out ASAP! That doesn't sound good!! [:@]
#2641
RE: THE LOUNGE 3...
ORIGINAL: Ttam Says Blarg
Yep got my check yesterday but not enough yet to buy the tundra. Nice lee very jealous
#2642
My Feedback: (31)
WV
RE: THE LOUNGE 3...
no the gears are out of production now... i even called tamiya directly.. no luck they basically said good luck finding those pal so i thought id ask you guys.. LB hit me with a pm about that blitzer
#2645
CA
RE: THE LOUNGE 3...
guess i spoke to soon on the RC10. It has stripped (partly) one of the internal "idler" gears... don't feel like spending the money to replace all the bushings with bearings.... so it will sit for now, problem is the bushings in there are so sloppy that they cause the gears to jam a lot causing all my issues. Guess it helps to have a good tranny [>:]
#2647
CA
RE: THE LOUNGE 3...
ORIGINAL: lee172
you run it with bushings?? [X(]
why didnt you get bearings in the first place?
#2648
RE: THE LOUNGE 3...
it isnt. back in the '80's they made the cars tuffer so that parts would last longer, if you get a new car instead of fixing this one you will spend more money on replacement parts and besides, it would be around $150 for a new motor, esc, radio, tires & rims f&r, a body and paint as apose to $230 for a b4 rtr
#2649
CA
RE: THE LOUNGE 3...
I have everything to make a "new" kit run MINUS the kit . I am debating it, you do have a point on durability, man idea is, don't crash [8D]
#2650
RE: THE LOUNGE 3...
Yeah I changed mine to bearings when I got the kit along time ago because I knew if I didnt get them when I got the kit, I wasnt going to get them at all or anytime soon.
You should take a break from it and go back to it later get, the gears before they stop selling them though
